SANtricity commands
Set target properties - SANtricity CLI
Contributors netapp-driley
The set target command changes the properties for an iSCSI/iSER target, including authentication method and alias name.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Context
Note
This command replaces the deprecated Set iSER target and Set iSCSI target properties commands.
Syntax
set target (["targetAliasName"] | <"targetQualifiedName">) (authenticationMethod=(none | chap chapSecret="newSecurityKey") | targetAlias="newAliasName")
Parameter Description
target
Allows you to specify which target you want to set. You can either specify the target's alias name or qualified name (e.g., iqn). Enclose the target identifier in double quotations marks (" "). You also must enclose the identifier in square brackets ([ ]) if it is an alias or angle brackets (< >) if it is a qualified name.
Allows you to set the means of authenticating your session. Valid choices are: none or chap.
chapSecret
Allows you to enter the security key to authenticate a peer connection. This is applicable only when authenticationMethod is set to chap.
targetAlias
Allows you to specify the new alias name for the target. Enclose the name in double quotation marks (" ").
Minimum firmware level
8.41
