Show signed certificate - SANtricity CLI
The show controller arrayManagementSignedCertificate summary command displays the current signed certificate summary from the specified controller.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
show controller [(a|b)] arrayManagementSignedCertificate summary
| Parameter | Description |
Allows you to specify the controller on which you want to retrieve the root/intermediate certificates. Valid controller identifiers are a or b, where a is the controller in slot A, and b is the controller in slot B. Enclose the controller identifier in square brackets ([ ]). |
Example
Sample output may be different than illustrated below.
SMcli -n Array1 -c "show controller[a] arrayManagementSignedCertificate all summary;" ============================ Controller A Signed Certificate ============================ Subject DN: CN=Corp Issuing CA 1 Issuer DN: CN=Corp Root CA Start: <date> Expire: <date> SMcli completed successfully.
Minimum firmware level
8.40
