SANtricity commands
Show consistency group - SANtricity CLI
Contributors netapp-driley
The show consistencyGroup command returns information about one or more consistency groups.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
show (allConsistencyGroups | consistencyGroup [consistencyGroupName] |
consistencyGroups [consistencyGroupName1 ... consistencyGroupNameN])
[(summary | schedule)]
Parameter Description
This setting returns information about all of the consistency groups in the storage array.
consistencyGroup
The name of the consistency group for which you are retrieving information. Enclose the consistency group name in square brackets ([ ]). If the consistency group name has special characters or numbers, you must enclose the consistency group name in double quotation marks (" ") inside square brackets.
consistencyGroups
The names of several consistency groups for which you are retrieving information. All of the volumes will have the same properties. Enter the names of the volumes using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Separate each of the names with a space.
If the volume names have special characters or consist only of numbers, enter the names using these rules:
  • Enclose each of the names in double quotation marks (" ").
summary
This setting returns a concise list of information about the consistency groups.
schedule
This parameter returns information about any schedules for a consistency group.
Minimum firmware level
7.83
