Show thin volume - SANtricity CLI
The show volume command returns the expansion history or the consumed capacity for the specified thin volume or volumes.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
show (allVolumes | volume [volumeName] |
volumes [volumeName1 ... volumeNameN])
(consumedCapacity |
(expansionHistory [file=fileName]))
| Parameter | Description |
This parameter returns information about all of the thin volumes in the storage array. |
The name of a thin volume for which you are retrieving information. Enclose the thin volume name in square brackets ([ ]). If the thin volume name has special characters or numbers, you must enclose the thin volume name in double quotation marks (" ") inside square brackets. |
The names of several thin volumes for which you want to retrieve information. Enter the names of the volumes using these rules:
If the volume names have special characters or numbers, enter the names using these rules:
The setting to return a concise list of information about the consumed capacity of the thin volumes. |
The setting to return a concise list of information about the expansion history of the thin volumes. |
The |
Notes
With the expansionHistory parameter, the command returns information similar to the example shown below.
Thin volume name: volume-nameRepository volume Name: REPOS_NNNN
| Logged Time | Expansion Type | Start Capacity | End Capacity |
MM/DD/YYYY HH:MM:SS |
Manual|Automatic |
NNNNNNNN bytes |
NNNNNNNN bytes |
With the consumedCapacity parameter, the command returns information similar to the example shown below.
| Volume | Provisioned Capacity | Consumed Capacity | Quota | % Prov.Consumed |
500.000 GB |
230.000 GB |
700.000 GB |
46% |
Minimum firmware level
7.83
