SANtricity commands
Delete snapshot volume - SANtricity CLI
Contributors netapp-driley netapp-maumita
The delete snapVolume command deletes a snapshot volume and optionally the associated snapshot repository members.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
You cannot use this command for snapshot images involved in online volume copy.
Syntax
delete snapVolume ["snapVolumeName"]
[deleteRepositoryMembers=(TRUE | FALSE)]
Parameter Description
snapVolume
The name of the snapshot volume that you want to delete. Enclose the snapshot volume name in double quotation marks (" ") inside square brackets ([ ]).
The parameter to save or delete the repository members. To save the repository members, set this parameter to FALSE. To delete the repository members, set this parameter to TRUE. The default value is TRUE. If you do not use this parameter, the repository members are automatically deleted.
Minimum firmware level
7.83
