SANtricity commands
Set host - SANtricity CLI
Contributors netapp-driley
The set host command assigns a host to a host group or moves a host to a different host group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
You can also create a new host group and assign the host to the new host group with this command. The actions performed by this command depend on whether the host has individual mappings or does not have individual mappings.
Syntax
set host [hostName]
hostGroup=("hostGroupName" | none | defaultGroup)
userLabel="newHostName"
hostType=(hostTypeIndexLabel | hostTypeIndexNumber)
Parameter Description
host
The name of the host that you want to assign to a host group. Enclose the host name in square brackets ([ ]). If the host name has special characters or numbers, you must enclose the host name in double quotation marks (" ") inside square brackets.
hostGroup
The name of the host group to which you want to assign the host. (The following table defines how the command runs if the host does or does not have individual mappings.) Enclose the host group name in double quotation marks (" "). The defaultGroup option is the host group that contains the host to which the volume is mapped.
userLabel
The new host name. Enclose the host name in double quotation marks (" ").
hostType
The index label or number of the host type for the host port. Use the show storageArray hostTypeTable command to generate a list of available host type identifiers. If the host type has special characters, enclose the host type in double quotation marks (" ").
Host Group Parameter Host Has Individual Mappings Host Does Not Have Individual Mappings
hostGroupName
The host is removed from the present host group and is placed under the new host group defined by hostGroupName.
none
The host is removed from the host group as an independent partition and is placed under the root node.
The host is removed from the present host group and is placed under the default group.
defaultGroup
The command fails.
Notes
When you use this command, you can specify one or more of the optional parameters.
For the names, you can use any combination of alphanumeric characters, hyphens, and underscores. Names can have a maximum of 30 characters.
Minimum firmware level
6.10
