Cancel asynchronous mirror group role reversal - SANtricity CLI
The stop asyncMirrorGroup rolechange command cancels a pending role reversal operation between asynchronous mirror groups.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
stop asyncMirrorGroup [asyncMirrorGroupName] rolechange
Parameter
| Parameter | Description |
The name of the asynchronous mirror group for which or which you want to cancel the pending role reversal operation. Enclose the asynchronous mirror group name in square brackets ([ ]). If the asynchronous mirror group name contains special characters or consists only of numbers, you must enclose the name in double quotation marks (" ") inside square brackets. |
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
