SANtricity commands
Set host channel - SANtricity CLI
Contributors netapp-driley
The set hostChannel command defines the loop ID for the host channel.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
set hostChannel [hostChannelNumber]
preferredID=portID
Parameter Description
hostChannel
The identifier number of the host channel for which you want to set the loop ID. Enclose the host channel identifier number in square brackets ([ ]).
Use a host channel value that is appropriate for your particular controller model. A controller tray might support one host channel or as many as eight host channels. Valid host channel values are a1, a2, a3, a4, a5, a6, a7, a8, b1, b2, b3, b4, b5, b6, b7, or b8.
preferredID
The port identifier for the specified host channel. Port ID values are 0 to 127.
Minimum firmware level
6.10
6.14 adds an update to the host channel identifier.
7.15 adds an update to the host channel identifier.
