SANtricity commands
Stop consistency group snapshot volume - SANtricity CLI
Contributors netapp-driley
The stop cgSnapVolume command stops the copy-on-write operation for creating a consistency group snapshot volume.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
To restart the copy-on-write operation use the resume cgSnapVolume command.
Note
This command does not delete a consistency group snapshot volume. To delete a consistency group snapshot volume use the delete cgSnapVolume command.
Syntax
stop cgSnapVolume [snapVolumeName]
Parameter
Parameter Description
cgSnapVolume
The name of the consistency group snapshot volume that you want to stop creating. Enclose the volume name in square brackets ([ ]). If the volume name has special characters or numbers, you must enclose the name in double quotation marks (" ") inside square brackets.
Minimum firmware level
7.83
