SANtricity commands
Set external key management settings - SANtricity CLI
Contributors netapp-driley
The set storageArray externalKeyManagement command configures the external key management server address and port number.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Note
This command applies only to external key management.
Syntax
set storageArray externalKeyManagement serverAddress=serverAddress
serverPort=portNumber
Parameter Description
serverAddress
Allows you to specify the external key management server address. The server address can be a fully qualified domain name, IPv4 address, or IPv6 address.
serverPort
Allows you to specify the port number of the external key management server.
Example
SMcli -n Array1 -c "set storageArray externalKeyManagement serverAddress=192.0.2.1 serverPort=8081;"
   SMcli completed successfully.
Minimum firmware level
8.40
