SANtricity commands
Resume asynchronous mirror group - SANtricity CLI
Contributors netapp-driley
The resume asyncMirrorGroup command resumes data transfer between all mirrored pairs in an asynchronous mirror group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Data written to the primary volumes while the asynchronous mirror group was suspended is written to the secondary volumes immediately. Periodic synchronization resumes if an automatic synchronization interval has been set.
Syntax
resume asyncMirrorGroup ["asyncMirrorGroupName"]
[deleteRecoveryPointIfNecessary]
Parameter Description
asyncMirrorGroup
The name of the asynchronous mirror group for which you want to start synchronization. Enclose the asynchronous mirror group name in double quotation marks (" ") inside square brackets ([ ]").
The parameter to delete the recovery point if the recoverable synchronization data has exceeded time threshold for recovery. Recovery point age is measured from the time the data was frozen on the primary storage array.
Minimum firmware level
7.84
8.10 adds the deleteRecoveryPointIfNecessary parameter
11.80 adds EF600 and EF300 array support
