SANtricity commands
Test AutoSupport delivery settings - SANtricity CLI
Contributors netapp-driley
The start storageArray autoSupport deliveryTest command sends a sample AutoSupport bundle collection message so you can test the connection to the destination technical support system using the specified delivery parameters.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
start storageArray autoSupport deliveryTest [replyToEmail="address"]
Parameter Description
replyToEmail
Allows the user to specify the reply-to email address for the AutoSupport test message. It is only used/required when delivery method is set to email.
SMcli -n Array1 -c "start storageArray autoSupport deliveryTest;"
SMcli -n Array1 -c "start storageArray autoSupport deliveryTest replyToEmail=\"user@company.com\";"
The sample AutoSupport message was successfully sent to the ASUP gateway server.
SMcli completed successfully.
Minimum firmware level
8.40
