Save storage array iSER statistics - SANtricity CLI
The save storageArray iserStatistics command saves the iSER performance statistics of the storage array to a file.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
This command is deprecated and is replaced by the Save storage array host port statistics command. |
Syntax
save storageArray iserStatistics [(raw | baseline)] file="filename"
| Parameter | Description |
The statistics collected are all statistics from the controller start-of-day. Enclose the parameter in square brackets ([ ]). |
The statistics that are collected are all statistics from the time the controllers were reset to zero using the |
The file path and the file name to which you want to save the performance statistics. Enclose the file name in double quotation marks (" "). For example:
The default name of the file that contains the iSCSI performance statistics is |
Notes
If you have not reset the iSER baseline statistics since the controller start-of-day, the time at the start-of-day is the default baseline time.
Minimum firmware level
8.20
8.41 This command is deprecated.
