SANtricity commands
Set host port - SANtricity CLI
Contributors netapp-driley
The set hostPort command changes the properties for a host port.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
This command does not work in an iSCSI environment, where the host ports are considered initiators. Instead, use the set iscsiInitiator command. See Set iSCSI initiator.
Syntax
set hostPort [portLabel] userLabel=newPortLabel
[host=hostName]
Parameter Description
hostPort
The name of the host port for which you want to change the host type, or for which you want to create a new name. Enclose the host port name in square brackets ([ ]). If the host port name has special characters or numbers, enclose the host port name in double quotation marks (" ") inside square brackets.
userLabel
The new name that you want to give to the host port. Enclose the new name of the host port in double quotation marks (" ").
host
The name of the host for which you are defining an HBA or HCA host port. Enclose the host name in double quotation marks (" ").
Notes
You can use any combination of alphanumeric characters, hyphens, and underscores for the user label. User labels can have a maximum of 30 characters.
Minimum firmware level
6.10
