SANtricity commands
Delete storage array syslog configuration - SANtricity CLI
Contributors netapp-driley netapp-maumita
The delete storageArray syslog command allows you to delete the specified syslog configuration used for storing audit logs.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
delete storageArray syslog (allServers | id="<id>")
Parameter Description
allServers
Delete all syslog configurations.
id
ID of the syslog server to delete. The ID is available using the show storageArray syslog command.
Minimum firmware level
8.42
