Update SNMP community - SANtricity CLI
The set snmpCommunity command creates a new name for an existing Simple Network Management Protocol (SNMP) community.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
set snmpCommunity communityName="snmpCommunityName"
newCommunityName="newSnmpCommunityName"
| Parameter | Description |
The name of the existing SNMP community that you want to rename. Enclose the SNMP community name in double quotation marks (" "). |
The new name that you want to give to the SNMP community. Enclose the SNMP community name in double quotation marks (" "). |
Minimum firmware level
8.30
