Start asynchronous mirroring synchronization - SANtricity CLI
The start asyncMirrorGroup synchronize command starts Asynchronous Mirroring synchronization.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
start asyncMirrorGroup ["asyncMirrorGroupName"] synchronize [deleteRecoveryPointIfNecessary]
Parameter
| Parameter | Description |
The name of the asynchronous mirror group for which you want to start synchronization. Enclose the asynchronous mirror group name in double quotation marks (" ") inside square brackets ([" "]). |
The parameter to delete the recovery point if the recoverable synchronization data has exceeded time threshold for recovery. Recovery point age is measured from the time the data was frozen on the primary storage array. |
Minimum firmware level
7.84
8.10 adds the deleteRecoveryPointIfNecessary parameter.
11.80 adds EF600 and EF300 array support
