SANtricity commands
Revive snapshot volume - SANtricity CLI
Contributors netapp-driley
The revive snapVolume command forces a specified snapshot volume to the Optimal state.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Context
The snapshot volume can be one of the following:
  • A standalone snapshot volume
  • A snapshot volume that is a member of a consistency group
If the snapshot volume is not in a Failed state, the firmware displays an error message and does not run this command.
Note
You cannot use this command for a snapshot volume that is used in online volume copy.
Syntax
revive snapVolume [snapVolumeName]
Parameter
Parameter Description
snapVolume
The name of the snapshot volume that you want to set to the Optimal state. Enclose the snapshot volume name in square brackets ([ ]). If the snapshot volume name has special characters or consists only of numbers, you must enclose the snapshot volume name in double quotation marks (" ") inside square brackets.
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
Minimum firmware level
7.83
