Show disk pool - SANtricity CLI
The show diskPool command returns information about a disk pool.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
This command returns this information about a disk pool:
The status (such as Optimal, Degraded, Failed, Missing)
The total capacity
The preservation capacity, usable capacity and unusable capacity
The used capacity, free capacity, and percentage full
The current owner (the controller in slot A or the controller in slot B )
The drive media (SAS)
The drive media type (HDD or SSD)
The drive interface type (Fibre Channel, iSCSI, InfiniBand, SAS)
Tray loss protection (yes or no)
Secure capable - indicates whether the disk pool is composed of all secure-capable drives. Secure-capable drives can be either FDE drives or FIPS drives.
Secure - Indicates whether the disk pool has drive security turned on (this is called secure enabled).
The remaining capacity notification settings (critical and early warning)
The priority settings
The associated volumes and free capacity
The associated drives
Data Assurance capabilities and presence of Data Assurance enabled volumes
Resource provisioning capabilities
Syntax
show diskPool [diskPoolName]
Parameter
| Parameter | Description |
The name of the disk pool for which you are retrieving information. Enclose the disk pool name in square brackets ([ ]). If the disk pool name has special characters or numbers, you must enclose the disk pool name in double quotation marks (" ") inside square brackets. |
Notes
Use this command to show the disk pool content of the storage array profile.
Minimum firmware level
7.83
