Show volume group export dependencies - SANtricity CLI
The show volumeGroup exportDependencies command shows a list of dependencies for the drives in a volume group that you want to move from one storage array to a second storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
show volumeGroup [volumeGroupName] exportDependencies
Parameter
| Parameter | Description |
The name of the volume group for which you want to show export dependencies. Enclose the volume group name in square brackets ([ ]). |
Notes
This command spins up the drives in a volume group, reads the DACstore, and shows a list of import dependencies for the volume group. The volume group must be in an Exported state or a Forced state.
Minimum firmware level
7.10
