Set iSCSI target properties - SANtricity CLI
The set iscsiTarget command defines properties for an iSCSI target.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
This command is deprecated and is replaced by the Set target properties command. |
Syntax
set iscsiTarget ["userLabel"]
authenticationMethod=(none | chap) |
chapSecret=securityKey |
targetAlias="userLabel"
| Parameter | Description |
The iSCSI target for which you want to set properties. Enclose the |
The means of authenticating your iSCSI session. |
The security key that you want to use to authenticate a peer connection. |
The new name that you want to use for the target. Enclose the name in double quotation marks (" "). |
Notes
Challenge Handshake Authentication Protocol (CHAP) is a protocol that authenticates the peer of a connection. CHAP is based upon the peers sharing a secret. A secret is a security key that is similar to a password.
Use the chapSecret parameter to set up the security keys for initiators that require a mutual authentication. The CHAP secret must be between 12 characters and 57 characters. This table lists the valid characters.
Space |
0 |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
A |
B |
C |
D |
E |
F |
G |
H |
I |
J |
K |
L |
M |
N |
O |
P |
Q |
R |
S |
T |
U |
V |
W |
X |
Y |
Z |
_ |
a |
b |
c |
d |
e |
f |
g |
h |
i |
j |
k |
l |
m |
n |
o |
p |
q |
r |
s |
t |
u |
v |
w |
x |
y |
z |
Minimum firmware level
7.10
8.41 This command is deprecated.
