SANtricity commands
Set initiator - SANtricity CLI
Contributors netapp-driley
The set initiator command updates the initiator object.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
This command replaces the deprecated Set iSCSI initiator command.
Note
This command is applicable only to iSCSI, iSER, NVMe over RoCE, NVMe over InfiniBand, and NVMe over Fibre Channel.
Syntax
set initiator (["initiatorName"] | <"initiatorQualifiedName">) ([userLabel="newInitiatorName"] |
[host="newHostName"] | [chapSecret="newSecurityKey"])
Parameter Description
initiator
Allows you to specify the initiator identifier for which you want to set properties. Enclose the name in double quotation marks ("` "`). You also must enclose the name in square brackets ([ ]) if the value is a user label or angle brackets (< >) if the value is a qualified name (e.g., iqn or nqn).
userLabel
Allows you to enter a new user label for the initiator object. Enclose the new user label in double quotation marks (" ").
host
Allows you to enter a new host to which the host port is connected. Enclose the host name in double quotation marks (" ").
chapSecret
Allows you to enter a new security key that you want to use to authenticate a peer connection. Enclose the security key in double quotation marks (" "). This parameter is only applicable to iSCSI and iSER host interface types.
Minimum firmware level
8.41
