SANtricity commands
Save storage array host port statistics - SANtricity CLI
Contributors netapp-driley
The save storageArray hostPortStatistics command saves the storage array host port statistics.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Security Admin role.
Syntax
save storageArray hostPortStatistics [(raw | baseline)] type=(ISCSI| ISER | SRP | NVMEOF) file="filename"
Parameter Description
raw
Allows you to retrieve the collected statistics since start-of-day. Enclose the parameter in square brackets ([ ]).
baseline
Allows you to retrieve the collected statistics from the time the controllers' baselines were reset to zero. Enclose the parameter in square brackets ([ ]).
type
Allows you to indicate which statistics type to collect. Valid choices are: ISCSI, ISER, SRP, and NVMEOF.
file
Allows you to specify the file path and filename to save the statistics. Enclose the file name in double quotation marks (" "). Use any file name with the .csv extension.
Type Ethernet MAC, Ethernet TCP/IP, Local Initiator (Protocol), DCBX Operational State, LLDP TLV, DCBX TLV Target (Protocol) InfiniBand Interface NVMe Subsystem ASUP Filename
iscsi
X
X
iser
X
X
srp
X
nvmeof
X
X
Minimum firmware level
8.41
