Add array label - SANtricity CLI
The Add array label command allows you to add a storage array to the configuration with a user-defined label. This allows later commands to address the storage array by the user-defined label rather than by IP address or host name.
Supported Arrays
The user-defined label provided does not need to match the storage array's name as displayed in System Manager. This is a local label that is only used for referencing the storage array from the CLI. |
This command applies to the EF600, EF300, EF50, and EF80 storage arrays.
Syntax
Address1 Address2 add storageArrayLabel label userDefinedString
| Parameter | Description | ||
Allows you to specify the IP address (IPv4 or IPv6) or fully qualified host name for the storage array.
Allows you to specify a label for the storage array. |
Minimum firmware level
8.60
