SANtricity commands
Set storage array password length - SANtricity CLI
Contributors netapp-driley
The set storageArray passwordlength command allows the admin user to set a minimum length for all new or updated passwords on the storage array.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
set storageArray passwordLength=<INTEGER>
Parameter Description
password length
Allows you to set the minimum required length for all new or updated passwords.
INTEGER
Allows you to set the minimum required length, between 0 and 30, for all new or updated passwords.
SMcli <array_ip> -u <username> -p <password> -c "set storageArray passwordLength=0;"
SMcli completed successfully.
Minimum firmware level
8.41 adds the command.
