SANtricity commands
Show volume performance statistics - SANtricity CLI
Contributors netapp-driley
The show volume performanceStats command returns information about volume performance.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Context
For each volume in the storage array, this command returns the following information:
  • Storage Arrays
  • Total IOs
  • Read %
  • Primary Read Cache Hit %
  • Primary Write Cache Hit %
  • SSD Cache Hit %
  • Current MBs/sec
  • Maximum MBs/sec
  • Current IOs/sec
  • Maximum IOs/sec
  • Minimum IOs/sec
  • Average IOs/sec
  • Minimum MBs/sec
  • Average MBs/sec
  • Current IO Latency
  • Maximum IO Latency
  • Minimum IO Latency
  • Average IO Latency
Syntax
show (allVolumes | volume ["volumeName"]
volumes ["volumeName1" ... "volumeNameN"]) performanceStats
Parameter Description
allVolumes
The parameter to return performance statistics about all of the volumes in the storage array.
volume
The name of a volume for which you want to retrieve information. Enclose the volume name in square brackets ([ ]). If the volume name has special characters or numbers, you must enclose the name in double quotation marks (" ") inside square brackets.
volumes
The names of several volumes for which you want to retrieve information. Enter the names of the volumes using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Separate each of the names with a space.
If the volume names have special characters or numbers, enter the names using these rules:
  • Enclose each of the names in double quotation marks (" ").
Notes
Before you run the show volume performanceStat command, run the set session performanceMonitorInterval command and the set session performanceMonitorIterations command to define how often you collect the statistics.
The show volume performanceStat command returns volume performance statistics as shown in this example:
Performance Monitor Statistics for Storage Array: Tyler -
Date/Time: 11/6/12 10:00: 34 AM - Polling interval in seconds: 5
"Storage Arrays","Total IOs","Read %","Primary Read Cache Hit %",
"Primary Write Cache Hit %","SSD Read Cache Hit %","Current MBs/sec",
"Maximum MBs/sec","Current IOs/sec","Maximum IOs/sec","Minimum IOs/sec",
"Average IOs/sec","Minimum MBs/sec","Average MBs/sec","Current IO Latency",
"Maximum IO Latency","Minimum IO Latency","Average IO Latency"
"Capture Iteration: 1","","","","","","","","","","","","","","","","",""
"Date/Time: 11/6/12 10:00:34 AM","","","","","","","","","","","","","","",
   "","","""Volume Unnamed","0.0","","0.0","0.0","0.0","0.0","0.0","0.0","0.0","0.0",
Minimum firmware level
6.10
