SANtricity commands
Stop volume copy - SANtricity CLI
Contributors netapp-driley
The stop volumeCopy target source command stops a volume copy operation. This command is valid for snapshot volume copy pairs.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
stop volumeCopy target [targetName] source [sourceName]
Parameter Description
target
The name of the target volume for which you want to stop a volume copy operation. Enclose the target volume name in square brackets ([ ]). If the target volume name has special characters or numbers, you must enclose the target volume name in double quotation marks (" ") inside square brackets.
source
The name of the source volume for which you want to stop a volume copy operation. Enclose the source volume name in square brackets ([ ]). If the source volume name has special characters or numbers, you must enclose the source volume name in double quotation marks (" ") inside square brackets.
