Set storage array directory server role mapping - SANtricity CLI
The set storageArray directoryServer roles command allows you to define role mappings for a specified directory server. These role mappings are used to authenticate users that attempt to execute various SMcli commands.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
What you'll need
The following roles are available to be mapped:
Storage admin — Full read/write access to the storage objects (for example, volumes and disk pools), but no access to the security configuration.
Security admin — Access to the security configuration in Access Management, certificate management, audit log management, and the ability to turn the legacy management interface (SYMbol) on or off.
Support admin — Access to all hardware resources on the storage array, failure data, MEL events, and controller firmware upgrades. No access to storage objects or the security configuration.
Monitor — Read-only access to all storage objects, but no access to the security configuration.
Syntax
set storageArray directoryServer ["domainId"]
groupDN="groupDistinguishedName" roles=("role1"..."roleN")
| Parameter | Description |
Allows you to specify the domain by its ID for which you want to set up role mappings. |
Allows you to specify the group's distinguished name (DN) to be added to the mapping list. |
Allows you to specify one or more roles for the user(s) in the defined group. If you enter more than one role, separate the values with a space. Valid choices are:
SMcli -n Array1 -c "set storageArray directoryServer ["domain1"]
groupDN="CN=ng-hsg-bc-madridsecurity,OU=Managed,
OU=MyCompanyGroups,DC=hq,DC=mycompany,DC=com"
roles=("storage.monitor" "security.admin" "storage.admin");"
groupDN="CN=ng-epg-engr-manageability,OU=Managed,
roles=("support.admin");"
SMcli completed successfully.
