SANtricity commands
Unregister SNMP trap destination - SANtricity CLI
Contributors netapp-driley netapp-maumita
The delete snmpTrapDestination command deletes an existing Simple Network Management Protocol (SNMP) trap destination that you previously created and registered using the create snmpTrapDestination command.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
delete snmpTrapDestination trapReceiverIP=ipAddress
Parameter Description
trapReceiverIP
The IP address of the SNMP manager from which you want to stop sending trap messages.
Minimum firmware level
8.30
