Save tray log - SANtricity CLI
The save allTrays logFile command saves the log sense data to a file.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Log sense data is maintained by the environmental cards for each tray. Not all of the environmental cards contain log sense data.
Syntax
save allTrays logFile="filename"
Parameter
| Parameter | Description |
The file path and the file name to which you want to save the log sense data. Enclose the file name in double quotation marks (" "). For example:
This command does not automatically append a file extension to the saved file. You must specify a file extension when entering the file name. |
Minimum firmware level
6.50
