Enable or disable AutoSupport at the EMW management domain level (SMcli only) - SANtricity CLI
The SMcli enable autoSupportFeature command turns on the AutoSupport (ASUP) feature for all managed storage arrays and makes it possible to transmit messages to the technical support site. After you enable the ASUP feature, any ASUP-capable storage array is automatically prepared to collect and send support-related data to technical support. The data can then be used for remote troubleshooting and problem analysis.
Supported Arrays
This command applies to all E2700 and E5600 storage arrays in the management domain at once. It does not apply to E4000, E2800, or E5700 storage arrays.
Context
This command is an SMcli command, not a script command. You must run this command from a command line. You cannot run this command from the script editor in the storage management software. |
The Persistent Monitor must be enabled for the AutoSupport feature to work. |
No customer data is ever transmitted to the technical support site. |
This command impacts all ASUP-capable storage arrays in the management domain. After enabling this feature for the management domain, you have control over the feature enablement for each storage array.
After enabling this feature, you can next enable the AutoSupport OnDemand feature (if desired), and then enable the AutoSupport Remote Diagnostics feature (if desired).
You must enable the three features in the following order:
Enable AutoSupport
Enable AutoSupport OnDemand
Enable AutoSupport Remote Diagnostics
Syntax
SMcli enable|disable autoSupportFeature
None.
Verification
Use the SMcli -autoSupportConfig show command to see whether you have enabled the feature. The initial line of the displayed output shows the enable status:
The AutoSupport feature is activated on this storage management station.
Minimum Firmware Level
7.86
