SANtricity commands
Show SNMPv3 USM user - SANtricity CLI
Contributors netapp-driley
The show allsnmpUsers command returns information about the Simple Network Management (SNMP) USM users defined for the storage array.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
show (allSnmpUsers |
    snmpUser userName="snmpUsername" |
    snmpUsers [snmpUserName1 ... snmpUserNameN])
    [summary]
Note
This command returns SNMP user information similar to the following
SNMP USERS------------------------------
SUMMARY
   Total SNMP Users: 2
   Total SNMP Trap Destinations: 1
DETAILS
   SNMP User: TestUser1
   SNMP Engine ID: local
   SNMP Permission: Read Only
   SNMP Authentication Protocol: sha
   SNMP Privacy Protocol: aes128
      Associated Trap Destination:
      Trap Receiver IP Address  Send Authentication Failure Traps
      10.113.173.133            false
   SNMP User: TestUser2
   SNMP Authentication Protocol: sha256
   SNMP Privacy Protocol: none
Parameter Description
allSnmpUsers
This parameter returns information about all of the SNMP users in the storage array.
userName
The name of the SNMP user for which you want to retrieve information. Enclose the SNMP user name in double quotation marks (" ").
snmpUsers
The names of several SNMP users for which you want to retrieve information. Enter the names of the SNMP users using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Enclose each of the names in double quotation marks (" ").
  • Separate each of the names with a space.
summary
This parameter returns a list of the total number of SNMP users and the total number of SNMP trap destinations. When you use this parameter, all of the detail information is omitted.
Minimum firmware level
8.72
