Getting started with internal key management - SANtricity CLI
A security key is a string of characters, which is shared between the secure-enabled drives and controllers in a storage array. When using internal key management, you create and maintain security keys on the controller's persistent memory.
See SANtricity System Manager online help for conceptual information on using internal security keys.
The following is the basic workflow for using internal security keys:
Create security keys
Set security keys
Validate security key
Workflow steps
The following commands get you started with internal security keys:
Create a storage array security key, using the
create storageArray securityKeycommand. See Creating a storage array security key. -
Set the storage array security key, using the
set storageArray securityKeycommand. See Setting a storage array security key. -
Validate the security key, using the
validate storageArray securityKeycommand. See Validating a storage array security key.
