SANtricity commands
Stop SSD cache locate - SANtricity CLI
Contributors netapp-driley
The stop ssdCache locate command turns off the indicator lights on the Solid State Disks (SSDs) that were turned on by the start ssdCache locate command.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Support Admin role.
Syntax
None.
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
