SANtricity commands
Start check volume parity job - SANtricity CLI
Contributors netapp-driley
The start check volume parity job command starts a new check volume parity operation on a given volume.
Supported Arrays
This command applies to any individual storage array, including the EF600, EF300, EF50, and EF80 arrays; as long as all SMcli packages are installed.
Roles
To execute this command on an EF600, EF300, EF50, and EF80 storage array, you must have the Storage Admin role.
Syntax
start check volume[<volume_label>] parity job
(startingLba=<start_lba> endingLba=<end_lba> scanPriority=<scan_priority> repairParityErrors=<true | false>
repairMediaErrors=<true | false>);
Parameter Description
startingLba
The volume logical block address where the parity scan will start. The default value is 0.
endingLba
The volume logical block address where the parity scan will stop. The default value is maximum volume lba.
scanPriority
The parity scan priority. The default value is medium
repairParityErrors
Determines whether to automatically attempt to repair parity errors detected during the parity scan. Default value is true.
repairMediaErrors
Determines whether to automatically attempt to repair media errors detected during the parity scan. Default value is true.
Minimum firmware level
11.80
