SANtricity commands
Revive snapshot group - SANtricity CLI
Contributors netapp-driley
The revive snapGroup command forces the specified snapshot group to the Optimal state.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Context
If the snapshot group is not in a Failed state, the firmware displays an error message and does not run this command.
Syntax
revive snapGroup [snapGroupName]
Parameter
Parameter Description
snapGroup
The name of the snapshot group that you want to set to the Optimal state. Enclose the snapshot group name in square brackets ([ ]). If the snapshot group name has special characters or consists only of numbers, you must enclose the snapshot group name in double quotation marks (" ") inside square brackets.
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
Minimum firmware level
7.83
