SANtricity commands
Set storage array to enable or disable cache mirror data assurance check - SANtricity CLI
Contributors netapp-driley
The set storageArray cacheMirrorDataAssuranceCheckEnable command allows you to enable or disable the cache mirror data assurance check.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
set storageArray cacheMirrorDataAssuranceCheckEnable=(TRUE | FALSE)
None.
Minimum firmware level
8.41 New command parameter.
