Show snapshot volumes - SANtricity CLI
The show snapVolume command returns information about one or more snapshot volumes.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
show (allSnapVolumes | snapVolume ["snapVolumeName"] |
snapVolumes ["snapVolumeName1" ... "snapVolumeNamen"])
[summary]
| Parameter | Description |
The parameter to return information about all of the snapshot volumes in the storage array. |
The name of a snapshot volume about which you want to retrieve information. Enclose the snapshot volume name in double quotation marks (" ") inside of square brackets ([ ]). |
The names of several snapshot volumes for which you want to retrieve information. Enter the names of the snapshot volumes using these rules:
The parameter to return a concise list of information about the snapshot volumes. |
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
This command returns snapshot volume information as shown in this example:
SNAPSHOT VOLUME (SNAPSHOT-IMAGE BASED) SUMMARY
SUMMARY Total Snapshot Volumes: 1 Most Recent Snapshot Volume: Day month date hh:mm:ss yyyy Status: 1 Optimal, 0 Non Optimal Name Type Status Capacity Associated Base Volume 2_SV_0001 Standard Optimal 3.000 GB 2
Snapshot Volume Timestamp Snapshot Image Timestamp Mode 1/23/12 6:44:31 PM IST 1/23/12 6:27:36 PM IST Read Write
Total Repository Capacity Available Repository Capacity 1.199 GB 0.125 MB (0%)
The size of your monitor determines how the information wraps and will affect how the information appears.
Minimum firmware level
7.83
