SANtricity commands
Reset storage array diagnostic data - SANtricity CLI
Contributors netapp-driley
The reset storageArray diagnosticData command resets the NVSRAM that contains the diagnostic data for the storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
This command does not delete the diagnostic data. This command replaces the Needs Attention status with the Diagnostic Data Available status. The old diagnostic data is written over automatically when new data is captured. The memory that contains the diagnostic data is also cleared when the controllers reboot. Before you reset the diagnostic data, use the save storageArray diagnosticData command to save the diagnostic data to a file.
Note
Run this command only with the assistance of technical support.
Syntax
None.
Minimum firmware level
6.16
