SANtricity commands
Add certificate from file - SANtricity CLI
Contributors netapp-driley
The Add certificate from file command allows you to take a certificate from the file and add it to the CLI package's trust store. The certificate added will only be used by the CLI package.
Supported Arrays
This command applies to the EF600, EF300, EF50, and EF80 storage arrays.
Syntax
trust localCertificate file filename alias user specified alias
Parameter Description
filename
Allows you to specify the filename that contains the certificate.
Allows you to specify a certificate through the user-defined alias.
Minimum firmware level
8.60
