Getting started with external key management - SANtricity CLI
A security key is a string of characters, which is shared between the secure-enabled drives and controllers in a storage array. When using external key management, you create and maintain security keys on a key management server
See SANtricity System Manager online help for conceptual information on using external key management servers and security keys.
The following is the basic workflow for implementing external security keys:
Generate a Certificate Signing request
Get client and server certificates from the KMIP server
Install the client certificate
Set the IP address and port number of the KMIP server
Test communication with KMIP server
Create a storage array security key
Validate the security key
Workflow steps
Both certificate management and external key management are new security features with the SANtricity11.40 release. To get started, use the following basic steps:
Generate a Certificate signing request using the
save storageArray keyManagementClientCSRcommand. See Generate Key Management certificate signing request. -
From the KMIP server, request a client and a server certificate.
Install the client certificate using the
download storageArray keyManagementCertificatecommand with thecertificateTypeparameter set toclient. See Install storage array external key management certificate. -
Install the server certificate using the
download storageArray keyManagementCertificatecommand with thecertificateTypeparameter set toserver. See Install storage array external key management certificate. -
Set the IP address and port number of the key management server using the
set storageArray externalKeyManagementcommand. See Set external key management settings. -
Test communication with the external key management server using the
start storageArray externalKeyManagement testcommand. See Test external key management communication. -
Create a security key using the
create storageArray securityKeycommand. See Create security key. -
Validate the security key using the
validate storageArray securityKeycommand. See Validate internal or external security key.
