Start volume initialization - SANtricity CLI
The start volume initialize command starts the formatting of a volume in a storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Formatting a volume starts a long-running operation that you cannot stop. |
Syntax
start volume [volumeName] initialize
Parameter
| Parameter | Description |
The name of a volume that you want to format. Enclose the volume name in square brackets ([ ]). If the volume name has special characters or numbers, you must enclose the name in double quotation marks (" ") inside square brackets. |
Minimum firmware level
6.10
