Learn about the structure of SANtricity CLI commands
The CLI commands are in the form of a command wrapper and elements embedded into the wrapper.
A CLI command consists of the following elements:
A command wrapper identified by the term
SMcli -
The storage array identifier
Terminals that define the operation to be performed
Script commands
The CLI command wrapper is a shell that identifies storage array controllers, embeds operational terminals, embeds script commands, and passes these values to the script engine.
All CLI commands have the following structure:
SMcli *storageArray terminal script-commands*;
SMcliinvokes the command line interface. -
storageArrayis the name or the IP address of the storage array. -
terminalis a CLI value that defines the environment and the purpose for the command. -
script-commandsare one or more script commands or the name of a script file that contains script commands. (The script commands configure and manage the storage array.)
If you enter an incomplete or inaccurate SMcli string that does not have the correct syntax, parameter names, options, or terminals, the script engine returns usage information.
