SANtricity commands
Update SNMP MIB II system group variables - SANtricity CLI
Contributors netapp-driley
The set snmpSystemVariables command changes the system variables for the Simple Network Management Protocol (SNMP).
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Context
The following system variables are maintained in a Management Information Base II (MIB-II) database:
  • Name of the system
  • Name of the system contact
  • Location of the system
Syntax
[sysName=newSystemName]
[sysContact=contactName]
[sysLocation=systemLocation]
Parameter Description
sysName
The new name that you want to give to the SNMP system. Use standard SNMP and MIB conventions for the system name. Enclose the SNMP system name in square brackets ([ ]).
sysContact
The name of contact person for the managed system with information on how to contact this person. Enclose the SNMP contact name in square brackets ([ ]).
sysLocation
The physical location of the system, such as "3rd flr". Enclose the SNMP system location in square brackets ([ ]).
Minimum firmware level
8.30
