SANtricity commands
Show volume reservations - SANtricity CLI
Contributors netapp-driley
The show volume reservations command returns information about the volumes that have persistent reservations.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
show (allVolumes | volume [volumeName] |
volumes [volumeName1 ... volumeNameN]) reservations
Parameter Description
allVolumes
The parameter to return performance statistics about all of the volumes in the storage array.
volume
The name of a volume for which you want to retrieve information. Enclose the volume name in square brackets ([ ]). If the volume name has special characters or numbers, you must enclose the name in double quotation marks (" ") inside square brackets.
volumes
The names of several volumes for which you want to retrieve information. Enter the names of the volumes using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Separate each of the names with a space.
If the volume names have special characters or numbers, enter the names using these rules:
  • Enclose each of the names in double quotation marks (" ").
Minimum firmware level
5.40
