SANtricity commands
Show synchronous mirroring volume candidates - SANtricity CLI
Contributors netapp-driley
The show syncMirror candidates command returns information about the candidate volumes on a remote storage array that you can use as secondary volumes in a Synchronous Mirroring configuration.
Supported Arrays
This command applies to any individual storage array, with some restrictions. If you are running the command on the E2700 or E5600 array, there are no restrictions.
Note
This command is not supported on E4000, E2800, E5700, EF600, EF300, EF50, and EF80 platforms.
Roles
N/A
Context
Note
In previous versions of this command the feature identifier was remoteMirror. This feature identifier is no longer valid and is replaced by syncMirror.
Syntax
show syncMirror candidates primary="volumeName"
remoteStorageArrayName="storageArrayName"
Parameter Description
primary
The name of the local volume that you want for the primary volume in the remote-mirrored pair. Enclose the primary volume name in double quotation marks (" ").
The remote storage array that contains possible volumes for a secondary volume. If the remote storage array name has special characters, you must also enclose the remote storage array name in double quotation marks (" ").
Minimum firmware level
5.40
