SANtricity commands
Show snapshot image - SANtricity CLI
Contributors netapp-driley
The show snapImage command returns information about the snapshot images that a user had previously created.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax for showing a specific snapshot image
show (allSnapImages | snapImage ["snapImageName"] |
snapImages ["snapImageName1" ... "snapImageNamen"])
[summary]
Parameter Description
allSnapImages
The parameter to return information about all of the snapshot images in the storage array.
snapImage
The name of a snapshot image for which you want to retrieve information. The name of a snapshot image is comprised of two parts:
  • The name of the snapshot group
  • An identifier for the snapshot image in the snapshot group
The identifier for the snapshot image can be one of these:
  • An integer value that is the sequence number of the snapshot in the snapshot group.
  • NEWEST — Use this option when you want to show the latest snapshot image created in the snapshot group.
  • OLDEST — Use this option when you want to show the earliest snapshot image created in the snapshot group.
Enclose the snapshot image name in double quotation marks (" ") inside square brackets ([ ]).
snapImages
The names of several snapshot images for which you want to retrieve information. Enter the names of the snapshot images using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Enclose each of the names in double quotation marks (" ").
  • Separate each of the names with a space.
summary
This parameter returns a concise list of information about the snapshot images.
Notes
The name of a snapshot image has two parts separated by a colon (:):
  • The identifier of the snapshot group
  • The identifier of the snapshot image
For example, if you want to show snapshot image 12345 in a snapshot group that has the name snapGroup1, you would use this command:
show snapImage ["snapGroup1:12345"];
To show the most recent snapshot image in a snapshot group that has the name snapGroup1, you would use this command:
show snapImage ["snapGroup1:newest"];
To show the snapshot images in several snapshot consistency groups that has the names snapGroup1, snapGroup2, and snapGroup3, you would use this command:
show snapImages ["snapGroup1:12345 snapGroup2:newest snapGroup3:oldest"];
Minimum firmware level
7.83
