Register SNMP trap destination - SANtricity CLI
The create snmpTrapDestination command creates a new Simple Network Management Protocol (SNMP) trap destination. A trap destination is the SNMP manager to receive the trap messages.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
create snmpTrapDestination trapReceiverIP=ipAddress
(communityName="communityName" | (userName="userName" [engineId=(local | engineId)]))
[sendAuthenticationFailureTraps=(TRUE | FALSE)]
| Parameter | Description |
The IP address of the SNMP manager to which you want to send trap messages. |
The name of the SNMP community for which you want to send trap messages. |
The name of the SNMP user for which you want to send trap messages. |
The engine ID of the SNMP user for which you want to send trap messages. The engine ID is required if there is more than one USM user with the same user name. The value may be " |
This parameter turns on or turns off sending authentication failure messages to an SNMP manager. To send authentication failure messages, set the parameter to |
Minimum firmware level
8.30
