SANtricity commands
Rename snapshot volume - SANtricity CLI
Contributors netapp-driley
The set snapVolume command renames an existing snapshot volume.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
set snapVolume ["snapVolumeName"] userLabel="snapImageVolumeName"
Parameter Description
snapVolume
The name of the snapshot volume that you want to rename. Enclose the snapshot volume name in double quotation marks (" ") inside of square brackets ([ ]).
userLabel
A new name that you want to give to the snapshot volume. Enclose the new snapshot volume name in double quotation marks (" ").
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
Minimum firmware level
7.83
