SANtricity commands
Unregister SNMP community - SANtricity CLI
Contributors netapp-driley netapp-maumita
The delete snmpCommunity command deletes an existing Simple Network Management Protocol (SNMP) community that you previously created and registered using the create snmpCommunity command. Deleting an SNMP community effectively unregisters the community. Any trap destinations associated with that community are also removed.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
delete snmpCommunity communityName="snmpCommunityName"
Parameter Description
communityName
The name of the SNMP community that you want to delete. Enclose the SNMP community name in double quotation marks (" ").
Minimum firmware level
8.30
